I own a 08 sxt and I installed the eibach sportline springs over the summer. After the springs had time to settle its developed a problem when it's very wet or snowy out. The rear end seems to want to wander a bit but sometimes it will start to sway very bad. The suspension is stock and when I get under it nothing seems overly wore or damaged. Would the current toe angles of the tires on the stock suspension be causing this? Any and all advice would be appreciated.
