Hey all,
I am currently having an issue while under WOT. My first thought would be overboost however this problem only happens around 9-10psi.
So as long as I am driving like a responsible adult it's fine. Even pushing it 3/4 throttle and under 10psi it doesn't have any issue. There is no CEL or codes present.
I checked the vacuum lines and doesn't seem to have a leak. Not sure if the cat is plugged. However the normal operation even at high rpm doesn't really indicate a plugged cat. A sensor might be the issue but no CEL or codes makes narrowing that down a real pain.
Wondering if anybody else has had a similar problem or if I am overlooking a problem somewhere else.
