Hi all,
I have a couple of questions regarding the security lock nuts on my OEM alloy wheels.
I own a 2.0 SXT and have noticed that the wheel nut lock key doesn't seem to be working anymore. I have used it before when changing the brake pads and had no problem with it, but when I went to check the nuts today before a long journey the key doesn't seem to get a good enough grip on the nut and just slips off.
Has anyone else had this problem?
Also, I have put the part number (05105834AA) found on the packaging of the lock key into Google and it brings up a Mopar wheel lock set. My question is will the new lock key be the same as the nuts on my car or will it be an entire different set? If the latter then how would I get the old lock nuts off of my car in order to fit the new ones?
Thanks in advance,
Luke
Thanks in advance,
Luke
