Where to locate your alcohol-water injection nozzle - Dodge Caliber Forums
post #1 of 7 Old 06-03-2010, 10:17 AM Thread Starter
DevilsOwn
Supporting Vendor
Points: 1,322, Level: 20 Points: 1,322, Level: 20 Points: 1,322, Level: 20
Level up: 22% Level up: 22% Level up: 22%
DevilsOwn's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Where to locate your alcohol-water injection nozzle.
Well let's first start with where not to place the nozzle. When placing your water injection nozzle makes sure you do not place the nozzle upstream of a MAF or mass air flow sensor. Fluid running through this sensor can damage these sensors on some particular engines. Next we recommend not installing these pre-intercooler unless you are injecting pre-blower on a supercharged engine that has an intake mounted intercooler. Injecting before front mount intercooler can cause the water-alcohol mixture to collect at the bottom because of the restriction of the tubes. Okay, now we know where not to place the nozzle, lets get on to where to place it.
Starting from where the air enters the intake tract and ending at the intake just prior to the combustion chamber.
1 Pre-Turbo water
We don't recommend this location at all if you do not have the proper equipment such as the proper nozzle, nozzle size and high pressure pump. Locating the nozzle here is the most controversial location. The majority of alcohol/water injection users do not use this location. One reason for someone to inject at this location is the water/methanol mixture chemically alters the turbo compressor map. The water/methanol injection will dynamically shifts the compressor map of the turbo so that it has the compressor map exhibits the characteristics of a larger turbo. This sounds great but, the main issue with pre-turbo nozzle placement is what mixture can damage the compressor blade if the mixture is not properly atomized when passing through the turbo.
In order to inject pre-turbo with out compressor damage you need a high quality low volume nozzle and high enough pressure to get the water as finely misted as possible, and the smaller nozzle which allows for smaller/finer water droplets. We recommend you mount the nozzle as close to the compresser as possible.
2 Pre-Intercooler
Pre-intercooler seems like a sensible nozzle location but, the thing to think about is if the air entering the IC is pre-cooled, the ability of the intercooler is because the temp difference is lesser. It is also possible for the fine water/alcohol mist to collect in the bottom of your intercooler core. We don't recommend this location either. The other problem is that there's a possibility that the hot air from the turbo might unnecessarily vaporize the water and take up some of the volume built up by the turbo that was supposed to be for the charge. Pre-IC does work for some track cars such as road racing that operate at a more constant higher RPM. For the daily driver, weekend racer, the pre-intercooler location should not be considered.
3 Post Intercooler
Most computer controlled engines have an intake air temperature (IAT) sensor. This sensor monitors the temperature of the air going into the motor. The reason for putting it before the IAT sensor is because it will see the cooler temps and the engine will advance timing, allowing for more power. Also placing the injection nozzle as far from the cylinders/air intake sensor as possible, it allows for the water/methanol mixture to be better absorbed into the intake air charge. This allows for great distribution to each cylinder. This post intercooler nozzle location should be the primary nozzle location to be considered for most users.
In theory, since the air charge will be mixed for a longer distance, and therefore time, allowing for the moisture to be absorbed by the air, creating the coolest possible air charge going into the cylinders. Water/methanol molecules from a nozzle located here have more time to be absorbed by the intake charge exiting the IC before making it into the combustion chamber.
4 Pre-Air Intake Temperature Sensor
In the cold side charge pipe is usually an easier or less intrusive nozzle location for most user's than the IC exit tank, but still the closer to IC the better. Locating the nozzle here has same as for reason given in above (location 3)
5 After Air Intake Sensor
After the Air Intake Sensor: You can usually mount it either before or after the ‘butterfly' and still be after the air intake temperature sensor. The main difference when mounting the injector before or after the butterfly is there is less vacuum before versus after the butterfly when idling or driving in vacuum. Translation, when in vacuum, there is more vacuum after the butterfly than before it. Here is why this is important: If your solenoid is placed very far from the injectors (more than a couple of feet), then the vacuum can actually suck just a little bit of the water/methanol. This small amount of moisture ingestion during vacuum is not a problem.
6Intake manifold
This location can be the most complex area to install. Usually requiring that he intake be removed for access. Injecting here is going to yield the largest water/methanol droplets. And with the closer proximity to the combustion chambers is going to provide a larger amount of mixture into the cylinders. Doing this usually requires more fuel from the factory system be removed. This option is best for max cooling.
The water here is being injected in a manner much like port fuel injection and it is the bigger water molecules being injected here that have a more direct effect of in cylinder cooling and injection here has more of an effect of altering the flame front of the combustion charge in a way much like a higher octane fuel. To take full advantage of this nozzle location it is suggested that trimming away some of the factory dumped fuel be done. In other words, in order to take advantage of the better properties of water over fuel for cooling and injecting water at this location, you want to remove the dumped fuel and actually REPLACE this with water. This injection point with a pretty sophisticated WI control method allows for the most advantageous use of water injection. The drawback for nozzles located heres is kit/component complexity, install complexity, additional labor, possible machine shop costs, and possible additional parts costs.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Sales/Support Phone Hours:
9am-6pm Monday-Friday (Central)
405-470-4356
DevilsOwn is offline
The Following 2 Users Say Thank You to DevilsOwn For This Useful Post:
AdubZ (06-04-2010), Black Sleeper (06-03-2010)
post #2 of 7 Old 06-03-2010, 07:51 PM
Tybalt
Senior Member
Points: 10,832, Level: 68 Points: 10,832, Level: 68 Points: 10,832, Level: 68
Level up: 96% Level up: 96% Level up: 96%
Tybalt's Avatar
Quoted: 0 Post(s)
can u give a suggestion on what kit to get and what type of switch?
Tybalt is offline
post #3 of 7 Old 06-04-2010, 07:59 AM
whodie
Senior Member
Points: 8,191, Level: 61 Points: 8,191, Level: 61 Points: 8,191, Level: 61
Level up: 14% Level up: 14% Level up: 14%
Quoted: 0 Post(s)
glad to see Devil's Own over here
I'm still a believe that WI should be after the IAT. If you are using an FIC or map clamp this would allow for more reliable tuning because you aren't chasing the timing advance - IMO
Sunburst Orange Pearl CSRT4
Realtune FTMFW!
whodie is offline
post #4 of 7 Old 06-04-2010, 08:39 AM Thread Starter
DevilsOwn
Supporting Vendor
DevilsOwn's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Quote:
http://www.alcohol-injection.com/wat...-15/srt-4-130/
These are the kits that will fit your application
Our dvc30 will also fit if you don't want a wire hookup to the cars map sensor and you just use ours. For the stage 1 kits you will want the 6-30 psi switch.
Thanks we are happy to be here.
I like it before because then you can monitor if the meth injection kit is cooling enough and if its not pull timing.
If anyone else has any other questions let me know.
post #5 of 7 Old 06-12-2010, 07:10 PM
turbojosrt4
Senior Member
Points: 5,042, Level: 45 Points: 5,042, Level: 45 Points: 5,042, Level: 45
Level up: 46% Level up: 46% Level up: 46%
turbojosrt4's Avatar
Quoted: 0 Post(s)
hummm interesting..... i dont want to start a "this is better then that" but can i get more detail on the before or after IAT sensor, on what whodie said I'm using a map clamp. So i would like to know the best setup/info before i take the plunge
08 cali srt4 silver
MoDs
Ms1 / Mpx Single Exhaust / Mpx Catless DP
Mpx Strut Bar / Mpx Dual Pods / NeedsWings HKS
AeroForce Gauge / AEM Wideband Gauge
NGK Iridium Plugs .32 / JMB 4" Intake
Road Magnet's Drag / Bwoody Check Valve
PtP 50% STS / DriverMod Tcs / Agp WasteGate
Rt Clamp / S1 Injectors / RT HighBoostKit
DevILs Own MetH
*347.8hp 364.8tq*
turbojosrt4 is offline
post #6 of 7 Old 06-13-2010, 09:54 PM Thread Starter
DevilsOwn
Supporting Vendor
DevilsOwn's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Quote:
I just like doing it before the iat because you can monitor whats going on with the meth kit. If its working, injection to much not enought. You can setup the ecu to pull timing if the iat are above 100 degs. I really just think its the best location.
post #7 of 7 Old 11-16-2010, 10:22 AM Thread Starter
DevilsOwn
Supporting Vendor
DevilsOwn's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hey guys!!!! Winter is here! Remember to make sure that you have at least 30% methanol in your mix. This will prevent lines from freezing, and keep your pump from having possible damage.
Anyone have any additional questions or concerns, please contact us.
The Following User Says Thank You to DevilsOwn For This Useful Post:
UN4GTBL (11-16-2010)
Reply
  Dodge Caliber Forums > Vendors > DevilsOwn Alcohol Injection
User Tag List
Show Printable Version Show Printable Version
Email this Page Email this Page
Linear Mode Linear Mode
Welcome DevilsOwn Alcohol Injection! Administrator DevilsOwn Alcohol Injection 7 06-04-2010 08:41 AM
alcohol injection dodgeluva Performance Discussion 1 12-21-2009 10:17 AM
Meth/Water injection 04srt4black Performance: Caliber SRT4 Specific 8 09-02-2008 04:06 PM
anyone using the DCR water injection kit? NEW2DODGE Performance: Caliber SRT4 Specific 0 09-01-2008 02:34 PM
Alcohol injection? jadenstate Performance: Caliber SRT4 Specific 8 07-15-2008 07:26 AM
For the best viewing experience please update your browser to Google Chrome
