Overheating issue needing help! - Dodge Caliber Forums
Problems / Dealer Service If you are having problems with your Dodge Caliber and you would like to discuss it, this is the section. Have your car into the dealer for a particular reason and want to talk about it? Do it in here.
post #1 of 8 Old 06-08-2019, 07:38 PM Thread Starter
Mike Kern
Junior Member
Points: 58, Level: 1 Points: 58, Level: 1 Points: 58, Level: 1
Level up: 16% Level up: 16% Level up: 16%
Activity: 100% Activity: 100% Activity: 100%
Quoted: 0 Post(s)
(Thread Starter)
Alright folks,
I am having an overheating issue and it only happens when I'm on the freeway or long stretches of road, fine in stop and go traffic and idling. also it will not over heat if I turn on the heater full blast.
here is the back story
I was gifted a 2007 Dodge caliber SE with a blown motor, no issue for me as I have done many engine rebuilds and swaps.
I found a motor with 49k miles the motor swap went great, along the way I replaced alot of the gaskets since I was in there, I also replaced both thermostats and the water pump to prevent issues, and the motor I purchased, didn't have either thermostat or water pump.
finished the swap 3 days ago and the car started right up no issue did the normal bleed (burp) the cooling system went out for a few short drives no issues at all had the ac system recharged and the alignment done.
decided to take it for a 30 minute drive temps were good, jumped on the freeway and the temp started to climb using my obd2 live to monitor the temp it went up to 240 F so thinking when I was younger I turned the heat on full blast and with in 10 seconds the temp dropped to 205 f. so I went home let it cool down check the fluids and nothing was low, I squeezed the hose to make sure I got the bubbles out.
At the point I'm like ok maybe it was a fluke and its fine I started it up and let it sit in the driveway for 30 minutes or so it got up to normal temp 205 so I was like ok lets test drive it,
fine in town hit the freeway again same issue.
so I looked online to ensure I didn't miss anything like a trick or a bleeder valve.
got home let it cool down, pulled both thermostats out didn't see any issues but I replaced them just because they were under warranty, the system seemed to be full of coolant when I pulled it apart,
so I put it back together and filled it up again, and hit the road for another test drive.
same issue only over heats when I am on the freeway or long stretches of road but if i turn on the heater full blast or its stop and go traffic or idling I have no issue.
any help at this point would be much appreciated.
thanks!
Mike Kern is offline
post #2 of 8 Old 06-12-2019, 04:56 PM
Styxer08
Junior Member
Feedback Score: 0 reviews
Quoted: 1 Post(s)
I would check if the fan is working, and see is there is a damaged, or clogged/ blocked up radiator.
Styxer08 is offline
post #3 of 8 Old 07-01-2019, 05:16 PM
Aeae121508
Junior Member
Aeae121508's Avatar
Quoted: 1 Post(s)
Hi, you sound like you know alot about cars and especially the caliber. I have a 2008 caliber and I have tried to do all the work i could on it by myself!! I have been pretty successful but i am now having an overheating problem but i can see my water pour out the bottom of radiator when I put coolant / water into the top. Do u happen to know where I can find a how to or instructions on removing the radiator so in can get a better look or possibly patch it up if need be or what would you recommend ? Thanks for the help ! Help from anyone would be awesome at this point !!!
Aeae121508 is offline
post #4 of 8 Old 07-01-2019, 10:37 PM Thread Starter
Mike Kern
Junior Member
Quoted: 0 Post(s)
(Thread Starter)
Talking its fixed!
Quote:
thanks for the advise
Sorry I kind of forgot about this page I did find my issue, 4 set of thermostats and I finally got a set that worked lol, everything runs great now!
post #5 of 8 Old 07-01-2019, 10:42 PM Thread Starter
Mike Kern
Junior Member
Quoted: 0 Post(s)
(Thread Starter)
Talking
Quote:
there isnt a tutorial but honestly if you cant getting water through the radiator I would replace the radiator, both thermostats, and flush the system, to ensure you get the best results put new clean coolant in the system, if you want faster responses you can contact me on facebook Mike Kern
post #6 of 8 Old 07-02-2019, 07:28 AM
Styxer08
Junior Member
Quoted: 1 Post(s)
I would look into where on the bottom. Drain plug area? Hose area? Water pump? Or radiator itself. Could end up being a much cheaper fix. I have a ‘12. It has a couple clips on the top. I don’t know about the older models.
Styxer08 is offline
post #7 of 8 Old 07-06-2019, 03:44 PM
Aeae121508
Junior Member
Aeae121508's Avatar
Quoted: 1 Post(s)
Thanks so much for your help ! I did go ahead and get another radiator! It was a pain getting it out ! Now I gotta put the new one in! Kinda stressed about getting back in totally correct. Why is there no diagram that I can seem to find anywhere ?? Do you know where I could find a decent diagram of the radiator w the ac compressor and fans like putting them together!
post #8 of 8 Old 07-07-2019, 04:28 AM
Styxer08
Junior Member
Quoted: 1 Post(s)
I would do a search on the dodge forum for caliber service manual. There are a few threads. 😉
Styxer08 is offline
Reply
  Dodge Caliber Forums > Dodge Caliber Discussion > Problems / Dealer Service
User Tag List
Show Printable Version Show Printable Version
Email this Page Email this Page
Linear Mode Linear Mode
For the best viewing experience please update your browser to Google Chrome
