1 - 10 of 10 Posts
I bought a 2007 Dodge Caliber SE from an auction online and I realize now that I must not take anything for granted. The car came without A/C. It was taken down to the dealer and the VIN is showing up that it did indeed came from the factory without. I think it is just ridiculous to even sell a car this day and age without A/C.
Without A/C, in these hot temperatures, won't cut it. Is it possible to have the A/C put in at this time? I have access to a caliber that was rolled over and all the parts for the A/C is in it. I am curious to know if it can be easily adapted provided I have all the parts.
If so, is there anything I should know about before I have it installed such as maybe a computer reset or activation? I would like to know as much as possible before I decide to put in it or not. IS it worth the hassle and cost?
Thanks in advance.
I dont think anyone on here has ever done it before, but you would need to change quite a lot to switch it over. Condenser, compressor, lines, new HVAC switch(assuming the wiring is there for the a/c button) and i would just about guarantee that the computer would need to be reflashed at the dealer.
Welcome to the forum :wave:
As SunBurst mentioned, there is a lot of work ahead to pull this off. If you are comfortable with a project like this, and have easy access to the parts and resourses to pull it off, I believe it can be done.
Discussion Starter #5
So I found a caliber that was rolled over and managed to get all the parts from that car and installed in the car with no AC. We connected the wires directly and managed to get the AC going. When we connected it using the wires the car came with we found out that all the plugs are dead with no power.
It now appears that the switches to the unit is dead. There is no power running to the connectors. I took it to the dealer and he attempted to flash it over but was unable to open the AC ports. I can only assume that because the car came with all the plugs in place that the computer would allow for the AC. I am not sure if I can trust the dealer. I feel like he does not know what he is doing.
He is asking to now get the computer and the TCM/TPM something like that and he can reset that to suit the car.
Do you guys know if the computer that came with the car has the capacity to have the AC opened?
I HIGHLY doubt that the computer is different from a caliber with ac and a caliber without ac..
With these cars, you never know though.. EVERYTHING is done through electronics..
I'm not surprised by this at all.
Considering that you have to flash the damn computer to get the fog lights to work, this seems completely possible as well.
Discussion Starter #8
In Need if AC Compressor Clutch
So I got the AC to finally work but the compressor is faulty. When it was taken down the clutch was bad.
I can't seem to locate the clutch only for the compressor.
Anybody have one on here willing to sell?
Jovan
i know this is an 8 year old post
hey jovan i am curious what you had to do to finally get the AC to work before you found out the compressor clutch was bad and also if you ever got it running properly.
1 - 10 of 10 Posts
