1 - 11 of 11 Posts
I just got some after market wheels this weekend. Unfortunately, the sensors for the tire pressure monitor wouldn't work with them.
Is there an easy way to disable to tire pressure warning light?
I thought the sensors for the pressure monitoring were in the valve stems. Didn't know they made wheels that normal valve stems wouldn't work in.
The sensors are actually in the Valve stem, but that is only a piece of the bigger transmitter that fits inside the wheel.
I've been looking for some aftermarket rims. I've tried finding the specs on the stock Caliber wheels so that I can get something that fits the same. I can't seem to find the numbers on the bolt pattern (spacing) or the offset. All I can find is standard emasurements (e.g. 17X7.5). Since I will most likely be ordering my rims online vs. going into a tire/wheel shop, getting the proper fitment the first time is important to me. Does anyone know the numbers for the bolt pattern and offset?
bolt pattern is 5/114.3mm (4.5")
offset? no idea! **
** edit >> http://www.autotrucktoys.com/dodge_caliber/Dodge-Caliber-17-Inch-Wheels-C3968.aspx?UserID=9809484&SessionID=wuHrjCg2DpjGgI2WhAwX
offset 40-45mm
Thank you. That will help me get the right wheels.
Michael K. said:
...I can't seem to find the numbers on the bolt pattern (spacing) or the offset. All I can find is standard emasurements (e.g. 17X7.5). Since I will most likely be ordering my rims online vs. going into a tire/wheel shop, getting the proper fitment the first time is important to me... Does anyone know the numbers for the bolt pattern and offset?
Been asked and posted a number of times, actually.
Do an Advanced Search on "offset" - you'll get 3 pages of results to read through! Seems there is a different offset for each tire size (15, 17, 18, aftermarket 20's).
I like the stock rims on the R/T and wasn't planning on changing mine but if I can get the SRT rims that may change my mind.
1 - 11 of 11 Posts
