1 - 5 of 5 Posts
The Pearl was mated perfectly with the Uconnect in the Caliber. This week (no new s/w updates done), the RIM/Uconnect started acting funny. Although both are paired to each other, when we now press the Uconnect button, we get the message 'Phone not ready" and the disconnect prompt.
I delete the pairing from each device, try again, new code, it pairs fine, but when I try to use Uconnect again, we get the same message.
I have been searching Blackberry forums, not sure what search words I should use and there are tons of hits, so I thought I would try here (of course, AFTER doing a search...
:mad:
Have you simply tryed rebooting the phone, or disabling bluetooth then reenabling it? On occasion my XV6700 wont connect and i just turn bluetooth off then back on.
Yes, and no. (yes to disable the Btooth). Will try to reboot the RIM and see what gives.
Thanks
My Telus version of the 6700 lost pairing about a week ago. I had to delete the original pairing and recreat it to get everything back to normal. I had been experimenting with the phone which may have contributed but I don't know for sure. Everything has been fine since. Turning on and off the BT radio (on the phone) has also been effective if I notice any phone / uConnect issues.
My Treo 650 will fail to connect now and then. It's usually my phones fault. It seems to only connect when I turn the ignition on. If my phone is not already on I have to turn the ignition off and then back on to get it to connect. For the most part it works great, just once in awhile it glitches.
1 - 5 of 5 Posts
