1 - 1 of 1 Posts
If you have a 2008-2010 Dodge Caliber SRT4 and want to improve your braking performance, help reduce/eliminate brake fade, this is one critical component.
Over time, the factory rubber brake lines degrade, and will expand with heat and higher brake fluid temperatures. This causes inconsistencies in brake pedal feel/brake clamp force.
This set of lines replaces the front and rear lines with stainless steel braided/reinforced brake lines that withstand heat MUCH better and dont expand. This will improve your brake pedal feel and driving enjoyment!
Replacement of these is straightforward, no modification of your stock lines, cutting, etc needed.
Link to order or for more info:
http://www.modernperformance.com/product/Goodridge_Stainless_steel_brake_line_kit_08_09_10_Caliber_SRT4/calibersrt4_brakes
1 - 1 of 1 Posts
