1 - 3 of 3 Posts
Ok I forgot what the panel that houses the A/C controllers, center A/C vents, and radio panel is call. Bezel-Center is what the service manual calls it. Anyways the manual only shows you how to remove it with pictures without stating where to start without breaking or if not snatching anything. It says to use a trim stick C-4755 but of course the Carbon Trim I got from Dodgeparts.com didnt come with it... How do you remove it?
I also got the lower part of the trim as will, the shift bezel, which the directions states to remove first. How do you remove that to?
1 - 3 of 3 Posts
