1 - 20 of 24 Posts
I thought a thread listing the common part store upgrades and maintenance parts with part numbers would nice to have.
I have gathered the below list from various threads on a couple sites.
Spark Plugs:
NGK Irdiums Stock heat Range (CSRT): BKR5EIX
NGK Stock plugs (CSRT): ZFR5FIX-11
NGK Irdiums One step cooler (CSRT): BKR6EIX
Champion 1.5 steps cooler (CSRT): RC9YCN4
Denso IR Power, Stock Heat Range (CSRT): IK16
Denso IR Power, 1 Step Colder (CSRT): IK20
Filters (air):
K&N drop-in air (CSRT): e-1988
Filters (oil):
Mobil1 oil filter (CSRT): Mobil1 M1-210
wix oil filter: 57899
Purolator PureOne (CSRT): PL24651
K&N Performance Gold (CSRT): HP-1017
Cabin Filters:
car quest: 90179P
wix: 24313
OEM: 5058693aa
Lights: (From Sylvania website)
High & low beam headlamp - H13 (9008)
Parking light - 3157NALL
Front turn signal - 3157NALL
Rear turn signal - 3157LL For 2007 Caliber will be different, as there is a seperate rear turn signal, it could be 3157NALL, but not sure
Tail light - 3157LL
Stop light - 3157LL
High mount stop light - LED Unit
Fog/Driving light - 9145
License plate - 2825
Back up light - 921
Front sidemarker - 3157NALL
Map light - 578
Dome light - 578
Fog Light Surrounds:
Passenger Side SRT Foglight Surround - 5030290AC
Driver Side SRT Foglight Surround - 5030291AC
Lower Bumper shield
SRT Plastic shield under bumper: 5030286AC
lighted door switches from a Charger:
driver door main: 04602780AA
single switches, other door: 04602787AA
Mopar Stage 1:
Before Jan 15, 2008: P5155175
After Jan 15, 2008: P5155199
Instruction Sheet: K6857152
OEM ECU:
After Jan 15, 2008: P05035043AC
Rotors
Centric Premium Front Rotors: 120.63072
Centric Premium Rear Rotors: 120.63069
Power Slot Front Slotted Rotors: 126.63072SL and 126.63072SR
Power Slot Rear Slotted Rotors: 126.63069SL and 126.63069SR
Batteries & Flash Light
Key battery (remote entry): type 2032
Dome light & Flashlight combo is 5183459AA - MSRP $68.50
Rechargeable battery is 5183454AA - MSRP $7.60
SRT Front Wheel bearing/hub assembly
OEM 5154211AA
SRT Brake Ducts
LH side: 05030293AC
RH side: 05030292AA
SRT Lower shield, W/SRT4 PANEL LOWER FASCIA
OEM: 5030286AC
I will add more as I find them. Please let me know if I am incorrect with any information
the correct number for for the stock plugs is actually zfr5fIX-11. however the only difference between the two plugs is the zfr has a projected insulator, which remains to be seen if it makes a difference or not.
Discussion Starter #7
Thanks for the additional parts and numbers.
I will try to keep the first post up to date.
If parts are model specific, please let me know.
Plugs:
Denso IR Power IK16(Stock Heat Range)
Denso IR Power IK20(1 Step Colder)
Oil Filters:
Purolator PureOne PL24651
K&N Performance Gold HP-1017
Sry yes these are for SRT's
Discussion Starter #12
Does anyone have any PN# for the non-SRTs?
I have a CSRT, but figured this would be valuable for both SRT and non-SRT owners.
Discussion Starter #13
Does anyone know the PN# for the stock heat Champion plugs?
I was going to go with NGK Irdiums, but after pricing out my first tune up, parts alone are going to hurt the wallet.
Discussion Starter #15
gtchrl:
I can confirm, the 13" blade fits perfectly.
It actually looks better then the short 11" that was on there originally.
1 - 20 of 24 Posts
