[U][B]Username:[/B][/U] wisque
[U][B]Location[/B][/U]: Foley, AL 36535
[U][B]Preferred Contact Method:[/B][/U] [email protected] or text me at 251-228-2089
[U][B]Item List:[/B][/U] 2008 Caliber SRT-4
[U]Item 1[/U]:
Description: Runs and drives. A/C and heat work great. Needs cosmetic work inside and out as shown in pictures that does not affect drivability. Needs a new carrier bearing on the intermediate shaft. Needs a broken stud replaced between the turbo and dp that has caused an exhaust leak. Has a check engine light on due to the exhaust leak and a broken hose on the evap canister. Also has lights on for ABS/traction and a few other issues I'm sure I'm forgetting. Has over 170k miles so could probably use a timing job. I currently drive it about 70 miles a day for work commute. Could use some suspension work. I've replaced all four wheel bearings, speed sensors, lca's, and religiously change the oil. Only mods it has that I'm aware of are turbo back mpx dual exit exhaust and a K&N intake that I installed myself.
Price and Shipping Terms: local pickup only
Picture(s):[ATTACH type="full"]11712[/ATTACH][ATTACH type="full"]11713[/ATTACH][ATTACH type="full"]11714[/ATTACH][ATTACH type="full"]11715[/ATTACH][ATTACH type="full"]11716[/ATTACH][ATTACH type="full"]11717[/ATTACH]
[U]Item 1[/U]:
