1 - 3 of 3 Posts
So this just started out the blue the end of last year, when starting the car you get a grinding noise like the starter is not fully engaging the flywheel. It takes a few trys to get in the right spot and actually start. Originally thought it was the starter out of how it started out, then changed out ignition switch(I thought it was fixed because I put a screwdriver in and started it up just fine) but after it was all back together it's still doing it. I dont know what else to change to try and fix this.
Discussion Starter #3
I know it's not that, when I had the ignition switch out and replaced it I put a screwdriver in it and it started just fine.
1 - 3 of 3 Posts
