1 - 20 of 30 Posts
Do all Caliber's come with the long mast antenna? I recall seeing pictures of a "shark fin" antenna on the cars instead of the giant one in front...
I think the european cars get the fin. Here in the states we are left with the whip. Its like the antenna i used to take off my fathers delta 88 and try and chop branches off of trees with.
Shark fin will be for the XM/Sirius sattelite radio.
Yes, all calis have the long mast. We replaced ours with an 18" black one. Much more gooder. ;)
Xtreme Thunder said:
Yeah, U.S.A. gets the whip and Europe gets the roof mounted short one. Any fin like antenna on a Caliber for '07 is for Sirrius.
You sure about that? I have that Sirrius thingy and I don't believe I have a fin.
I have been looking into replacing the antenna as it looks terrible.
Where did you pick up that antenna? I'd like a more gooder antenna as well :X
Can someone confirm me on this...it may not be a "fin", rather a smaller flat black piece on the roof toward the wing for Sirius.
Poor choice of words on my part.
Confirmed! I've seen the shark type antenna on some bmw's and other cars. I happen to like the Sirrius antenna that is on the Caliber.
ashram said:
there is an ongoing thread here
http://www.caliberforums.com/forums/showthread.php?t=800
various pics and info are spread throughout...
Thank you for posting this; there are several previous informative discussions about this topic (that can be located with the search feature) and that contain links to where to buy the optional antennas.
This one mentions and pictures the "shark fin" style antenna; however, I don't believe anyone has found out whether one is available for the Caliber yet:
http://www.caliberforums.com/forums/showthread.php?t=1037
Picked mine up at Canadian Tire yesterday. Stainless steel Black. Comes with all the adapters. Took 5 minutes to replace and looks so much better.
Here it is, straight from the manufacturer's 5 thousand + pages service manual.​
ANTENNA-SATELLITE
DESCRIPTION​
The satellite radio antenna is secured by adhesive foam and retainers which protrude through a hole in the roof
panel. Two wires from the antenna are connected to the body harness above the headliner.
OPERATION​
The satellite radio antenna receives signals from orbiting satellites and sends these signals to the satellite receiver
module. The satellite radio antenna must have open space in which to operate. Items carried on the roof, parking
inside etc. can have an effect on the antenna’s ability to receive signals.
And yet there is more.​
ANTENNA BODY AND CABLE
DESCRIPTION – Fixed Mast Antenna
The antenna body and cable are secured below the fender panel by the antenna cap nut through a mounting hole in the side of the right front fender. The primary coaxial antenna cable is then routed beneath the fender sheet metal and through an entry hole in the right cowl side panel into the interior of the vehicle. Inside the vehicle, the primary coaxial cable is connected to a secondary instrument panel antenna coaxial cable with an in-line connector that is located behind the right end of the instrument panel. The secondary coaxial cable is then routed behind the instrument panel to the back of the radio.​
DESCRIPTION – Roof Mounted Antenna
The roof mounted antenna is a combination antenna that is used for the reception of Amplitude Modulation (AM) frequencies, Frequency Modulated (FM) frequencies and Satellite signals for the Digital Satellite Radio. The primary coaxial antenna cable is then routed through an entry hole in the roof panel into the interior of the vehicle. Inside the vehicle, the primary coaxial cable is connected to a secondary instrument panel antenna coaxial cable with an inline connector that is located behind the right end of the instrument panel. The secondary coaxial cable is then routed behind the instrument panel to the back of the radio.​
If you don't like the stock "mast" antenna, you could always do what I did:
How much and do you know the Model?
It was the only model they had in stainless steel black. All the rest were chrome and retractable. Cost about 15 bucks. Let me know if you still want the brand name. I'll dig the package out of the trash. :)
I'd like the brand name. I was gonna get the 13" one from e-bay but alot of people said they were sh*t. I'm gonna go take a lookee at Can Tire today and see what i can find.
1 - 20 of 30 Posts
