hm... so once chance is the challengerswitch?!
mmh.... next project...
Do it!! :rocker:hm... so once chance is the challengerswitch?!
oh, well in that case take the part numbers from the first post and go order them!I could really care less about auto down - I find it annoying sometimes even on my drivers side...
just had my parts guy check and the driver side switch is backordered but the rest are in stock..hmmmm
He's referring to the passenger/rear window lockout button the the drivers side switch.UN4 - In your first post you said
(when you test the switches in the passenger door, make sure that those widows are not locked out by the master switch, as I found out the hard way, when the other windows are locked out, their lights are off)
Where is this Master switch? and if they are locked out, how do you unlock them?
Thanks,
Collector-X
Just like bruce said, the drivers door switch has a window lock out switch, make sure that its not locking out the other windows.UN4 - In your first post you said
Thanks,
Collector-X
Welcome back stranger!Just did the mod to my front switches, UN4GTBL we are in your debt!! I'm so pleased with this, especially as I do a lot of night driving. Thanks!
Yeah thats the avenger auto up & down switch, we figured out that doesn't workI thought I saw that p/n # 04602781AA would work on the drivers door but it has a different connector than the original one so it doesn't fit. I guess that I need 04602780AA instead
Great :bigthumb:I just did this - took an hour start to finish, and that included driving to the Dealer to pickup the new switches, so 20-30 minutes total labor on car.
Total cost $76.00 for all 4 switches.
Not as of yet.Has there been a confirmed double auto down switch that works as a replacement for the driver side switch?
