HOW-TO: Illuminated Window Switches
55307 Views 176 Replies 40 Participants Last post by  WookiesrPpl
8
*Update* There are two procedures for this process now.
For the 2007 to 2009 Calibers, the part numbers and instructions are below.
For the 2010-2012 Calibers, the how-to (although similar) starts here: 2010-2012 Instructions and Part Numbers
2007-2009 Part Numbers:
Driver's Door Part Number: 04602780AA
All other doors: 04602787AA (x3)
(From a Dodge Charger)
Plug and play too! No more having to take electronics apart! :bigthumb:
Step One: Pop off the screw cap, and remove screw in the pull cup
Step Two:
Slowly, and carefully, start to remove the bolster. I found its best to start around the middle of the top of the bolster with something that won't gouge up the plastic. Once its started, work your hand around, and pull the rest of the clips out. The bolster is still attached to the door by a couple of supports, so you don't have to worry about dropping it.
Step Three:
Carefully peel back the foam surrounding the plugs underneath. (The green tape is what i did, when i took them off before to paint my arm rest areas on my doors.)
Step Four:
Unplug the connectors
Step Five:
Carefully remove the switches from their places. I think that they all have about 6 tabs holding them to the bolster.
New (Left) VS. Factory (Right)
Step Six:
Plug in the new switch, to make sure it works. (when you test the switches in the passenger door, make sure that those widows are not locked out by the master switch, as I found out the hard way, when the other windows are locked out, their lights are off) Then follow the above steps in reverse order, and repeat for each door.
See less See more
Reactions: 5
141 - 160 of 177 Posts
Will those part #'s work on the 09' Caliber SXT?
what year charger do i need to grab these from im going to the junk yard tomorrow.
I got them from an '07 model, worked awesome!
I can't see why they wouldn't
As long as the switches look the same, I assume they will work. Try and double check the part numbers though
Bump for new members
Anyone know if they will work on a 2010 (my apologies if someone did already say...so much info overload... my eyes are @[email protected])? Guess we`ll find out soon enough though. I ordered the part #`s that were on the op.
I don't think we have had any feedback for the 2010+ Caliber.
Hopefully they do! If you are able to do a How-To for the 2010+ I would be able to add the pictures to this one, so its all in one place.
I`m hoping. They look the same as what I have so we`ll see. Doubt if we will pick up a new camera to replace the broken one but if we do, I`ll take pics. I`m assuming it`s pretty much the same but not sure. I`d have to take a closer look at everything.
oh ok. do you have cell phone that could take pics maybe?
i am thinking for how to take apart the door and such. the window switches look the same, so hopefully its all good for you
Got the 2 parts in (the same ones as described in the op). Was 45.50 for the drivers side and 8.95 for the passenger. Just doing the front. More than likely I won`t be able to do this until Sunday but if I can swing it, I`ll try Friday evening. I`ll also try to remember to take pics with my phone...;)
Reactions: 1
sweet! Hope it goes well!
2
So, was actually able to get at this today. Got home earlier than expected from our little trip, so I decided to knock it out and get it done with. Also, got a little lucky. Was walking through Meijers last night and just happened to glance over at the cameras and whatta ya know...they were having a 50% clearance...so yeah. Was able to pick up a good camera cheap to replace the one that hasn't worked for the last few years...:p
As for the job itself, I should have paid attention. After getting the front passenger side off and taking the switch out, I noticed the replacement one was a little small...The 2010 Mainstreet ( and I`m guessing the other models that have power doors) have the power door lock switches on it as well compared to your earlier year model ones with just the window switch only. So back in went the OE switch. The drivers side is the same as the older one and worked like a charm. There were a few minor differences in the newer model as to how they were built. You`ll see in the pics. Other than that, overall pretty much the same.
I`ll write up a small how-to for the experience.
See less See more
Reactions: 1
*Upon just verifying, I went and looked at the back door switches and they do not have the power locks on them so it appears that the smaller 04602787AA would fit the back doors as they are they same in look and size. I`m not doing the back doors but it appears that for the 2010 and up models you would have to order three types of switches if you wanted to do all doors.
Reactions: 1
5
I`m going to copy parts of UN4GTBL`s post and change/modify it to update for the 2010+ Calibers to make it similar and easier. :)
As mentioned above, for the 2010+ Calibers, you will need 3 types of switches. 1 Drivers side, 1 Front passenger side, and 2 Back passenger switches. When I find out what the part # for the front passenger door is, I`ll edit it in at that point.
Part Numbers:
Front Passenger Door: Unknown yet - new for 2010+
Back Passenger Doors: 04602787AA (x2)
Step One: Pop up the screw cap cover, and remove screw in the pull cup. -The 2010+ have new screw cap covers and also, the "handle" area is now "separate" from where the switch is as compared to earlier year models. The cover has a "snap-in" latch on the end of the right side that snaps in when you press/close it and is much bigger than earlier year model cap covers. Fingernail didn`t work for me so I took a very small flathead screwdriver and pried it up in the middle in the crease nearest you. Be VERY careful and gentle so as not to dent/damage the plastic.
Step Two: Slowly, and carefully, start to remove the bolster. I found its best to start around the middle of the top of the bolster with something that won't gouge up the plastic. Once its started, work your hand around, and pull the rest of the clips out. The bolster is still attached to the door by a couple of supports, so you don't have to worry about dropping it. -This is where you need the most patience. If you can, get some plastic door panel tools to make this easier. I highly recommend it. Just slowly try to finagle them out. This will take up the majority of your time. The worst for me were the clips on the side towards the door opening. Oh, if you watch closely and look at the clips themselves as you are doing this, you`ll notice how they latch in and then take that knowledge when trying to wiggle them out. This helps some if you can figure the trick to them. :)
Step Three: Carefully peel back the foam surrounding the plugs underneath. -Pretty much the same as earlier models. A tad different in look but the same overall.
Step Four: Unplug the connectors. -Same for all years.
Step Five: Carefully remove the switches from their places. I think that they all have about 6 tabs holding them to the bolster. -Same for all years.
Step Six: Plug in the new switch, to make sure it works. (when you test the switches in the passenger door, make sure that those windows are not locked out by the master switch, as I found out the hard way, when the other windows are locked out, their lights are off). Then follow the above steps in reverse order, and repeat for each door. -Same for all years.
See less See more
Reactions: 2
Cool. I forgot how that the 2010s have the power lock button on the passenger door as well. Still don't understand why the 07-09 didn't, but what ever.
Reactions: 1
Nice update to your op! :bigthumb:
Reactions: 1
thanks. i'm *hoping* to avoid confusion!
Reactions: 1
Applicable 2010 Pics are now in the how-to post above. Any other info is the same as the original OP. Enjoy!
Reactions: 2
I´m thinking about replacing at least the switch in the driver's door, too. What do you think, would a putty knife be suitable for removing the door panel?
btw: the dealer in Germany wants 45.- EUR (about 60.- USD) just for the driver's door switch. That's pretty sick!
Ouch, 60 bucks for one. Maybe check with another dealer? Dunno, maybe it is worth it in your eyes so get it if you want. Sometimes we pay more for things we want...but it`s always good to check around. As for the putty knife, probably depends on the quality and material it`s made of. I believe at most it would just help be a support to wedge it while you can get your hands/other tool in to pry out the other snaps. At worst, it will break like the first spatula I used lol. Good luck.
Reactions: 1
