1 - 2 of 2 Posts
I have an 08 SRT4 that came with no fob and I want to get one. I just want to make sure it will work and would like to know if there is a specific key style for this car/fob program before I buy one online lol
Thanks! :)
If you would like a key fob to open your 08SRT4. Car remotes can be programmed to any vehicle as long as the correct frequency is used and all of the information on the remote is coded with the correct information about that car. Keyless remotes require either a mechanical or electrical limit switch that will activate when pressed from either inside or outside of the car in order for it to work, otherwise it will simply not open even if positioned next to an already unlocked door. Mechanicals are cheaper but more vulnerable because they stick out from the lock and so they can break off if mishandled. Electrics, on the other hand,
1 - 2 of 2 Posts
