The latest car and driver has an article on the SRT. Why the hell would Dodge use an Aluminum block with this type of performance. The current SRT-4 uses cast iron. Granted it's heavier, but it will withstand more punishment (ie, modding).
because its lighter, probobly not much cheaper, but def. lighter. and your wrong about iron withstanding more power. take a look at the ls1 and ls2 small blocks. aluminum blocks and the block withstands easily 1200 hp. another example the cobalt ss or ecotec motor. the block in that is aluminum also and drag cars use stock blocks and they handle 1300 hp.Xxsrt4xX said:The latest car and driver has an article on the SRT. Why the hell would Dodge use an Aluminum block with this type of performance. The current SRT-4 uses cast iron. Granted it's heavier, but it will withstand more punishment (ie, modding).
Not wrong with iron withstanding more power. More power = higher temps. Yeah, aluminum can dissipate more, but it has a lower threashold to overheating. It is lighter than iron which attributes to better gas mileage. Follow this link ----> http://www.kellogg.northwestern.edu/news/hits/001018lat.htmleakslikasieve said:because its lighter, probobly not much cheaper, but def. lighter. and your wrong about iron withstanding more power. take a look at the ls1 and ls2 small blocks. aluminum blocks and the block withstands easily 1200 hp. another example the cobalt ss or ecotec motor. the block in that is aluminum also and drag cars use stock blocks and they handle 1300 hp.
its more the parts within the block then the block itself with these new motors.
Yeah, ur not, but I have noticed a lot of negative people on these boards..........well, let's just leave it at that.caliber4whoosh said:I know, and you did. No one that I know of was trying to start a flame war.![]()
Actually, the benefit of using an Aluminum Block is that it matches the coefficient of linear expansion of the Aluminum Head; as they heat up, they grow at the same rate.Xxsrt4xX said:The latest car and driver has an article on the SRT. Why the hell would Dodge use an Aluminum block with this type of performance. The current SRT-4 uses cast iron. Granted it's heavier, but it will withstand more punishment (ie, modding).
Silverfox said:Unless you're going to be throwing tens of thousands of dollars into the engine to reach the magical 1,000 horsepower mark, I really don't see a need for cast iron blocks in the SRT-4. Aluminum can withstand enough punishment for what the car will be doing. I can imagine you can get up to 800 HP or more out of the block as it is. The Neon's was rated at, what, 700?
