I know this has probably been asked a million and one times before, but I need to know a few simple things. I did do a search and could not find what I needed.
I have a 2007 Caliber SXT with the Musicgate System in it. What I wanted to know is: Could I add another sub and amp and keep the stock sub/amp and speakers? I do not want to change anything, I just want to add another sub and a amp to power it.
I have not seen anything on anyone doing this.
Pretty much I would end up with the stock system, 8 speakers 1 sub/amp plus 1 or 2 subs with another amp. Is it possible? How easy would it be? I figure I would just have the subs/amp sitting in the back by the other sub...
Yep, you can add if you want. Just need a GOOD Line output converter, but i would honestly use something like a signal processor. Then you just need to run the power, ground, remote, and rca's, and hook everything up.
Fairly easy to do, unless you have never installed an amp and sub, in which case i would take it somewhere.
Discussion Starter #3
Okay but it would work without messing any of the stock audio up? I have never done a sub or amp but I have friends who have..
Nope, you would be fine. I honestly would probably disconnect the factory sub though, you wouldnt hear it over whatever you put in there anyway
As SunBurst has mentioned, it's really easy. Check the 'how to' section and you'll find threads with all the info and even photos.
A really quick and dirty break down of what you will need to do is;
  • Run a fused power cable from the battery to the trunk (inline fuse)
  • Run a ground wire from a screw or bolt attached to the body in the trunk. Clear any paint that would come between the wire and the body so you have good contact. I generally look for screws already used for grounding like you will find around your tail lights.
  • Run a remote wire to turn on your amp. This is best connected to the cig lighter (12V outlet) in the front of the car.
  • Connect a high to low line converter. This can be tapped into the speaker wire at the head unit.
im pretty sure i have a how to with pics on here, not sure if the pics are still up or not though, as ive done some moving in my photobucket lately
Discussion Starter #7
Okay, that sounds good... How would I go about disconnecting the factory sub? Just unhooking it from the sub or from the amp?
I always thought a small screen between the two speakers would be cool. right where the handle is but you could rig up a different release mechanism.
