I installed a set of projector headlights with the Halo's and other leds, but while searching out which lights to get I came across this:
Installation Info: These lights will follow the same installation/removal procedures as your OEM lights.
**For lights with additional features such as halo rings or LED's there will be a 2 wire hookup that will need to be wired for your vehicle. We offer a relay diagram by request that uses the parking light circuit to turn the halos on and off to avoid adding a secondary switch inside the vehicle. To install using this method a 12 volt Bosch relay will be needed and can be purchased at most local auto parts, and car audio shops. Please click here to contact us via e-mail for relay diagram.
Once I installed the projectors I did notice that the led's brightness kinda sucked, the halos are very dim too. Would hooking up this relay, configuration from above, fix this problem? Is it really necessary? I already bought all the materials for the modification, but I am now wondering about the value of this recommendation.
Have any of you heard of this set up or used it?
Heres the link to the site where I found this info (these are the lights i ended up buying, but not from this vendor):
http://www.drivenbystyle.com/0710-dodge-caliber-halo-projector-head-lights-black-p-54751.html
I have the 2009 CSXT
