Well, not quite easy, but......there is an LED flash light installed in your Caliber. Maybe that helps with the light problem :rolleyes:
As for the engine: NO
Read the fine print on the engine shroud!!!!
If you have an automatic transmission on a SE or SXT it has to be a 2.0 Liter. I am almost sure the R/T only comes with the 2.4 Liter. If you have a standard transmission it should be a 1.8 Liter on an SE or SXT.
Open the hood on the Caliber, there should be a large plastic piece that says either, 1.8 VVT, 2.0 VVT, or 2.4 VVT.
Steveb is correct too.
