1 - 3 of 3 Posts
Does anyone know where the Sirius box is located on the Calibers that have factory installed satellite radios?
Thanks,
I believe its under the spare tire well.
Remove rear cargo liner, you will find a black colored cover raised above the floor level just behind the rear seat (dr side). Sneak a peak in side and you will be surprised what you find. The connectors are on the drivers side under the rear window at cargo bed level.
From the good book...
DESCRIPTION​
The satellite receiver module is located behind the spare tire. It is mounted to a bracket which is fastened to the trunk floor sheet metal.
Happy hunting.
1 - 3 of 3 Posts
