Hello, I would like to replace the factory speakers and add some to the spots in the dash. I have the base system which sounds ok, through my work I can get some speakers real cheap and am thinking that pretty much any brand will sound better than stock which is most likely a paper spkr with wiz cone and no more. Not looking to spend tons of money as it already sound ok, but heck I do not mind spending $40.00 on a set of 3ways just to see if it makes a difference. I am already adding a Rockford Fosgate 8" Sub in a Q Logic Box for the main bass with an Infinitiy Amp which I got a deal on at Frys.
Has anyone gotten into the doors yet? When you look at it, it looks like it would be easy to take a look and see what is there, but after a few minutes of closer inspection, it is not so easy to see what is in there.
I know there was a post about sizes being 6x9 in the doors which if true is great, but I wanted to check depth and see if the special sound mats could be added as well to cut down on vibraton from the speakers. Also said 2.5" full range in dash, which no one makes, I have looked everywhere, I wonder if they meant 3.5" since there are lots of those.
Any thoughts or info is helpful. Thanks, Flaps.
