1 - 5 of 5 Posts
MagNite said:
Ever pull up to a stoplight and you have to lean forward see the light overhead? Well this little gadget solves that. Someone posted it on a Magnum forum that I'm a member of so I bought one about a month ago. It works great. Thought I'd share.
http://www.lightinsight.com/
Isn't it just as easy to NOT pull up so far that you cannot see it? :p
Yeh, sometimes that works. But I've had the occasion NOT to be on the sensor to initiate the light change. As a result, I sat there a while before realizing that I needed to pull up a bit.
I think the gadget is perfect!
Tyke
Unfortunately, not all stoplights are designed well, so sometimes the stoplight isn't easy to see unless you lean forward. Also, many modern cars have a much more raked windshield then the cars of yesteryear when the stoplights were installed. I bought one of these and it works great, so I thought I'd share.
1 - 5 of 5 Posts
