I am hoping the noise is from the bushings, but part of me is uncertain so I will explain the noise:
1st off, the front bar is a tight fit behind the wheel (I'm not 100% caught up on the terms/naming of the components). It almost seems as if the bar would rub up against the front mounting bolt of the cross member (either side) if the suspension compressed even slightly.
The bar is installed the 'right way' as it goes over the steering.
Anyways, every littler 'bump' in the road makes a rubbing/vibration sound from the suspension; the bigger the bump, the louder the sound. It's clunky sounding on big bumps, but on slight bumbs it sounds more like rubbing. Its hard to see if there is any rubbing where I described, but it looks like there might be.
Is it possible the cross member is making this sound if its not tight enough?
Any thoughts, or if this looks the same on 'your' setup (assuming 'you' have the mopar sway bars installed)
Any input is appreciated...or even a picture of how the way should look behind the wheels would be greatly appreciated!
Thanks.
Thanks.
