n1vek said:
n00b question on tinting.
Does a higher or lower percentage mean the tints will be darker?
Depends if you look at it as
if you want to let a % of light through
or
if you want to block a % of the light
Usually the higher the number the darker it is, check local laws before doing it. They may present the % in one of the ways I listed above
example: The law may say 80% of sunlight must enter the windows, so you must get at max a 20% tint to allow for at least 80% sunlight to enter the vehicle.
Also can be presented the opposite way, example, must only block a max of 25% of the sunlight then it is just that number or less.
