WOW!
Thanks Grease, I am sure that this might help a lot of people!
Mod should sticky That!
And that's from another Thread from EssOurTeaFour:
Front Suspenion Torque Specs in Ft-Lbs.
Hub And Bearing Mounting Bolts - SRT4 60
Hub Nut 180
Lower Ball Joint Stud Pinch Bolt 60
Lower Control Arm Front Pivot Bolt (Built up to 8/1/08) 100
Lower Control Arm Front Pivot Bolt (Built After 8/1/08) 118
Lower Control Arm Rear Pivot Bolt 135
Stabilizer Bar Cushion Retainer Screws 22
Stabilizer Bar Link Nuts 43
Strut Clevis-to-Knuckle Nuts 81
Strut Rod Nut 44
Strut-to-Tower Nuts 35
Tie Rod Adjuster Jam Nut 55
Tie Rod End-to-Knuckle Nut 97
Wheel Mounting (Lug) Nuts 100
Rear Suspenion Torque Specs in Ft-Lbs.
Hub And Bearing Mounting Bolts 77
Hub Nut 181
Lower Control Arm Trailing Link Bolt Nut 70
Lower Control Arm Crossmember Mounting Bolt Nut 70
Shock Assembly Lower Mounting Bolt Nut 73
Shock Assembly Upper Mounting Nuts 35
Shock Rod Nut 18
Stabilizer Bar Cushion Retainer Screws 25
Stabilizer Link Mounting Nuts 43
Toe Link Trailing Link Mounting Bolt 70
Toe Link Mounting Cam Bolt Nut 26
Trailing Link Body Mounting Bolts 81
Upper Control Arm Trailing Link Bolt Nut 70
Upper Control Arm Crossmember Mounting Bolt 70
Hub Nut 180
Strut Rod Nut 44
Hub Nut 181
Shock Rod Nut 18
