1 - 6 of 6 Posts
I have a 2007 caliber SXT and had a diagnostic done because the blinkers and front/rear windshield wipers were not working. Diagnostic showed that the totally intergrated control module was the problem. I have also seen online a part called the totally intergrated power module. Is this the same part? Where is this part located? Thanks for your help. (any idea where to get one resonably priced, this is probably going to be expensive)
Just because the code shows that the module is malfunctioning doesn't always mean the module should be replaced, it could be another problem. As for the names, they should be the same.
The TIPM is an integral part of the fuse box under the hood.
What you describe as a fault is usually associated with the
TIPM and best case is reset with a reflash using Starscan
at dealership worse case abt $700.00 replacement out of
warranty.
Have you tried disconnecting negative battery cable for abt
10 minutes?
Part# 4692169AA (from '07 parts manual)
Reactions: kyli125 and UN4GTBL
warranty.
Have you tried diconnecting negative battery cable for abt
10 minutes?
i second the disconnecting the battery idea
1 - 6 of 6 Posts
