Wheel spacers
2674 Views 6 Replies 6 Participants Last post by  672AQ
Has anyone used wheel spacers, cuz I don't like the way the wheels sit so Far under the car
1 - 7 of 7 Posts
A number of guys have used them. I'm actually considering adding some to the rear wheels. Just be sure to replace your OEM studs with longer ones.
The spacers I'm using have studs on the spacers
I have both
extended ARP studs on the front wheels so I can use a 10mm slide on spacer with my drag wheels w/slicks
and I use a bolt on 25mm rear spacer that has the studs on the spacer
both work.....it's your choice:pimp:
I have used BONOSS wheel spacers, it’s very good.
1 - 7 of 7 Posts
