1 - 2 of 2 Posts
Has anyone purchased the DCX Stock trailer wiring harness for the Caliber yet? If so, is it easy to hook up (plug and play setup?) I cannot find an aftermarket one yet.
It will be easy, and expensive.
For $20, you can buy the 4 to 3 wire converter, non powered, and mount that inside the cab to protect it from the elements, having to run the connector outside when needed which will be less then when not needed. When not needed, the connector will dangle outside subject to corrosion.
S
1 - 2 of 2 Posts
