First connect the XTOOL X100 PAD to the Dodge Challenger via the Bluetooth VCI box that plugs into the OBD port of the ignition, turn on the XTOOL X100 PAD and open the main menu.
Go to Immobilization, find Dodge, then select Dodge 08-12.
Select Security Read Code to get the PIN first -Calculate code.
Soon you will receive the Dodge Challenger pin code 1069 as follows:
Then back to the selection Program new key.
Follow the instructions: Turn on the ignition of the Cars off, insert the new key you want to program, then turn on the ignition
And you need to enter the PIN code 1069
It starts with the programming of the new key. Wait patiently for the process to complete.
If you see the message Program Success, it means that the XTOOL X100 Pad Key Programmer has successfully created a new key fob for the Dodge Challenger!
